Mathematic to different columns
Hello!
I have this flux command:
from(bucket: "data")
  |> filter(fn: (r) => r["_measurement"] == "PV")
  |> filter(fn: (r) => r["Wechselrichter"] == "1")
  |> filter(fn: (r) => r["String"] == "1" or r["String"] == "2")
  |> filter(fn: (r) => r["_field"] == "power")
  |> yield(name: "mean")
So I get 2 tables or 2 columns?
I want to set a mathematic operation on both values, but not the same:
String 1: _value * 100 /3700
String 2: _value * 100 / 5940
With a map I always calc both elements … how can I set different mathematic operations?
Thank you!
Hello @hanhoe,
Make sure you’re using int or float when you perform the math.
You can do the following:
solution 1:
data = from(bucket: "data")
data1= data
  |> filter(fn: (r) => r["String"] == "1")
  |> map(fn: (r) => ({r with _value: r._value * 100/3700}))
  |> yield(name: "data1")
data2= data
  |> map(fn: (r) => ({r with _value: r._value * 100/5940}))
solution 2
|> map(
        fn: (r) => ({r with
            _value: if r.String == "1" then
                r._value * 100/3700
            else
               r._value * 100/5940,
The first solution is more performant most likely.
Thank you
Hi @Anaisdg one question: how can I use the variable data1 in data2?
For example, lets asumme that data1 returns one value as in |> mean()
in data2, can I do the following?:
data2= data
  |> map(fn: (r) => ({r with _value: r._value * data1}))
  |> yield(name: "data2")
