Map into one query
I’m trying to decode status and warnings from a jk bms, the question is how i get this into one query. I need to add fields based on one of the queried fields.
import "experimental/bitwise"
status = from(bucket: "ad")
  |> filter(fn: (r) => r["_measurement"] == "SolarHalle")
  |> filter(fn: (r) => r["Device"] == "bms")
  |> filter(fn: (r) => r["_field"] == "status")
  |> map(fn: (r) => ({ r with
    lowCapacity: int(v: bool(v: bitwise.sand(a: bitwise.srshift(a: int(v: r._value), b: 0), b:1))),
    mosOvertemp: int(v: bool(v: bitwise.sand(a: bitwise.srshift(a: int(v: r._value), b: 1), b:1)))
  |> drop(columns: ["_field", "_value", "Device", "_start", "_stop"])
  info = from(bucket: "ad")
  |> filter(fn: (r) => r["_field"] == "info")
    chargeOff: int (v: not bool(v: bitwise.sand(a: bitwise.srshift(a: int(v: r._value), b: 0), b:1))),
    dischargeOff: int(v: not bool(v: bitwise.sand(a: bitwise.srshift(a: int(v: r._value), b: 1), b:1)))
  join(tables: {s: status, i: info}, on: ["_time"], method: "inner")
  |> drop(columns: ["_measurement_i","_measurement_s"])
  |> yield(name: "mean")
Hello @ardiehl,
I’m sorry I’m not sure I understand.
Could you share your output and what you’d like your output to be? What do you mean by one query?
It seems like you could do:
  |> filter(fn: (r) => r["_field"] == "status" or r["_field"] == "info")
    lowCapacity/chargeOff: int(v: bool(v: bitwise.sand(a: bitwise.srshift(a: int(v: r._value), b: 0), b:1))),
    mosOvertemp/dischargOff: int(v: bool(v: bitwise.sand(a: bitwise.srshift(a: int(v: r._value), b: 1), b:1)))
is that what you mean?
