I have two buckets that log data from systems metrics and metrics_pg using telegraf to with the input modules cpu, mem, system, disk and others enabled.
I run a query using the python API every 10 minutes which computes the percent used memory per host and send it to a slack channel.
mem_available=from(bucket: "metrics")
|> range(start: -5m)
|> filter(fn: (r) => r["_measurement"] == "mem")
|> filter(fn: (r) => r["_field"] == "available")
|> aggregateWindow(every: 5m, fn: last, createEmpty: false)
mem_total=from(bucket: "metrics")
|> range(start: -5m)
|> filter(fn: (r) => r["_field"] == "total")
percent_used=join(
on: ["_time", "_stop", "_start", "host"],
tables: {mem_total, mem_available}
|> map(fn: (r) => (
_time: r._time,
_value: (r._value_mem_total - r._value_mem_available) * 100 /r._value_mem_total,
host: r.host
percent_used
This has been working fine since it was created a month ago but as of yesterday the influx query for the metrics bucket fails, however the same query changing the bucket to metrics_pg works fine.
Running this query in the influxdb2 web UI returns the error
panic: runtime error: index out of range [1] with length 1
The influxdb log has the following error for the query
ts=2020-12-22T05:01:20.615541Z lvl=info msg="Dispatcher panic" log_id=0R6Twn5W000 service=storage-reads component=dispatcher error="panic: runtime error: index out of range [1] with length 1" stacktrace="goroutine 58898134 [running]:
runtime/debug.Stack(0xc0083d1740, 0x39b7c00, 0x271f737)
/usr/local/go/src/runtime/debug/stack.go:24 +0x9f
github.com/influxdata/flux/execute.(*poolDispatcher).Start.func1.1(0xc0083d17a0)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/execute/dispatcher.go:81 +0x1e5
panic(0x259cc60, 0xc013e58980)
/usr/local/go/src/runtime/panic.go:969 +0x1b9
github.com/apache/arrow/go/arrow/bitutil.BitIsNotSet(...)
/go/pkg/mod/github.com/apache/arrow/go/arrow@v0.0.0-20200923215132-ac86123a3f01/bitutil/bitutil.go:48
github.com/apache/arrow/go/arrow/array.(*array).IsNull(...)
/go/pkg/mod/github.com/apache/arrow/go/arrow@v0.0.0-20200923215132-ac86123a3f01/array/array.go:112
github.com/influxdata/flux/execute.ValueForRow(0x3a2c880, 0xc0145d25a0, 0x8, 0x1, 0xc00dc8a2d0, 0xc00dc8a2d0)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/execute/table.go:491 +0xcf1
github.com/influxdata/flux/execute.(*rowFn).eval(0xc016f6ab40, 0x3a07c60, 0xc013b36930, 0x8, 0x3a2c880, 0xc0145d25a0, 0x0, 0x3a3db01, 0x2, 0x3, ...)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/execute/row_fn.go:190 +0xbf
github.com/influxdata/flux/execute.(*RowMapPreparedFn).Eval(0xc016f6ab40, 0x3a07c60, 0xc013b36930, 0x8, 0x3a2c880, 0xc0145d25a0, 0x3a32fa0, 0xc002d7dcc0, 0x0, 0x0)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/execute/row_fn.go:285 +0x75
github.com/influxdata/flux/stdlib/universe.(*mapTransformation).Process.func1(0x3a2c880, 0xc0145d25a0, 0xc0180cdfa0, 0xc000c1bc68)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/stdlib/universe/map.go:155 +0x105
github.com/influxdata/flux/execute.(*ColListTable).Do(0xc0145d25a0, 0xc00e4e9e60, 0xa, 0x10)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/execute/table.go:1410 +0x74
github.com/influxdata/flux/stdlib/universe.(*mapTransformation).Process(0xc00589bcc0, 0x775a8cde7841293f, 0xc6d42d56a939ef85, 0x3a0f8a0, 0xc0145d25a0, 0x5, 0x0)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/stdlib/universe/map.go:152 +0xeb
github.com/influxdata/flux/execute.processMessage(0x3a07c60, 0xc013b36930, 0x3a21460, 0xc00589bcc0, 0x39de1a0, 0xc017efad00, 0xc0083d1600, 0x0, 0x0)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/execute/transport.go:243 +0x30d
github.com/influxdata/flux/execute.(*consecutiveTransport).processMessages(0xc00f20c620, 0x3a07c60, 0xc013b36930, 0xa)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/execute/transport.go:191 +0xb8
github.com/influxdata/flux/execute.(*poolDispatcher).run(0xc0083d17a0, 0x3a07c60, 0xc013b36930)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/execute/dispatcher.go:132 +0x65
github.com/influxdata/flux/execute.(*poolDispatcher).Start.func1(0xc0083d17a0, 0x3a07c60, 0xc013b36930)
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/execute/dispatcher.go:86 +0x87
created by github.com/influxdata/flux/execute.(*poolDispatcher).Start
/go/pkg/mod/github.com/influxdata/flux@v0.95.0/execute/dispatcher.go:63 +0x7e
running the queries for mem_available, mem_total and the query except for the map function works fine.
It seems like there is something in this map function that triggers the panic only for the metrics bucket
|> map(fn: (r) => (
_time: r._time,
host: r.host
Any help will with this will be much appreciated
