Ahoy!
I am looking for some help with a continuous query. Here is the query, copy-pasted from my SHOW CONTINUOUS QUERIES output:
CREATE CONTINUOUS QUERY cq_snmp_interface_total ON telegraf RESAMPLE EVERY 1m FOR 1m BEGIN SELECT sum(bits) INTO telegraf.autogen.test_traffic FROM (SELECT non_negative_derivative(mean(ifHCInOctets), 1s) * 8 AS bits FROM telegraf.autogen.snmp_hcinterfaces WHERE (time > now() - 1m AND agent_host = '10.42.56.4' AND ifName =~ /^reth\d+$/) GROUP BY time(1m), *) GROUP BY time(1m), agent_host, device_model, device_type, env, host, instance, minion_id, primary_role, project, site, sysName END
Here is the same thing with line-breaks and indentation added for clarity:
ON telegraf
BEGIN
SELECT sum(bits)
FROM (
END
This query runs at the expected 1 minute interval. I can see it in the logs. It produces no error messages, but it also writes no data points. The telegraf.autogen.test_traffic measurement is not created.
Here is what the logs say:
Jun 26 07:43:00 influxdb-0 influxd[1721]: ts=2020-06-26T11:43:00.120238Z lvl=info msg="Continuous query execution (start)" log_id=0NAXIJ10000 service=continuous_querier trace_id=0Nd6r660000 op_name=continuous_querier_execute op_event=start
Jun 26 07:43:00 influxdb-0 influxd[1721]: ts=2020-06-26T11:43:00.120272Z lvl=info msg="Executing continuous query" log_id=0NAXIJ10000 service=continuous_querier trace_id=0Nd6r660000 op_name=continuous_querier_execute name=cq_snmp_interface_total db_instance=telegraf start=2020-06-26T11:42:00.000000Z end=2020-06-26T11:43:00.000000Z
Jun 26 07:43:00 influxdb-0 influxd[1721]: ts=2020-06-26T11:43:00.120402Z lvl=info msg="Executing query" log_id=0NAXIJ10000 service=query query="SELECT sum(bits) INTO telegraf.autogen.test_traffic FROM (SELECT non_negative_derivative(mean(ifHCInOctets), 1s) * 8 AS bits FROM telegraf.autogen.snmp_hcinterfaces WHERE (time > now() - 1m AND agent_host = '10.42.56.4' AND ifName =~ /^reth\\d+$/) GROUP BY time(1m), *) WHERE time >= '2020-06-26T11:42:00Z' AND time < '2020-06-26T11:43:00Z' GROUP BY time(1m), agent_host, device_model, device_type, env, host, instance, minion_id, primary_role, project, site, sysName"
Jun 26 07:43:00 influxdb-0 influxd[1721]: ts=2020-06-26T11:43:00.125790Z lvl=info msg="Finished continuous query" log_id=0NAXIJ10000 service=continuous_querier trace_id=0Nd6r660000 op_name=continuous_querier_execute name=cq_snmp_interface_total db_instance=telegraf written=0 start=2020-06-26T11:42:00.000000Z end=2020-06-26T11:43:00.000000Z duration=5ms
Jun 26 07:43:00 influxdb-0 influxd[1721]: ts=2020-06-26T11:43:00.125848Z lvl=info msg="Continuous query execution (end)" log_id=0NAXIJ10000 service=continuous_querier trace_id=0Nd6r660000 op_name=continuous_querier_execute op_event=end op_elapsed=5.621ms
If I run the exact same query directly without using a continuous query, then it works perfectly, and the correct data points are written into the test_traffic measurement
^ this works exactly as intended
Does anybody have any idea what I could be doing wrong?
