Hi There,
ATM I try to create a query which calculates the dew point from Temp C° and Absolute Humidity.
I found the correct formula, but I’m unable to translate it properly to Influxlang
I know, the formula is not finished yet, but as soon as I use any math functions like LOG() or LN() I get null returns.
this query without LN()
SELECT (mean(“Wohnzimmer_AbsoluteHumidity”)) FROM “exec_netatmo” WHERE timeFilter GROUP BY time(__interval) fill(previous)
returns
|2019-04-18 10:29:20|7.92|
|2019-04-18 10:29:00|7.92|
|2019-04-18 10:28:40|7.88|
|2019-04-18 10:28:20|7.88|
But this equal query with LN() returns absolutely nothing.
SELECT LN(mean(“Wohnzimmer_AbsoluteHumidity”)) FROM “exec_netatmo” WHERE timeFilter GROUP BY time(__interval) fill(previous)
Where is my syntax mistake ??!
I’m using InfluxDB 1.6 on a LXC Container with Ubuntu 16
and latest Grafana as front-end in Docker container.
