List Tasks based on Template
If I create a Template in Kapacitor, then I create 100 tasks on that template, how can I see from the list of tasks which template (if any) the tasks is using?
Likewise, if I list the template how do I see which tasks are using the template.
If I am going to modify a template then I need to know the impact of doing so.
Agreed, it should be easy to query the impact of changing a template.
The CLI doesn’t make this very easy at the moment. Currently with the CLI you have to kapacitor show each task and grep out the template name.
I have created this issue to track improving the API to make this easier. Expose Template Task association via the API and CLI · Issue #1368 · influxdata/kapacitor · GitHub
