Given test data with measurement m, series srs, from 2021-01-01T00:00:00Z to 2021-02-01T00:00:00Z, every 1 minute.
When I execute a query like this:
from(bucket: "b1")
|> range(start: 2021-01-01)
|> filter(fn: (r) => r._measurement == "m" and r._field == "srs")
|> last()
I don’t get the last record but the record with _time = 2021-01-03T23:59:00Z.
Furthermore when I change the range start to the time of the next record after the above result _time (2021-01-04T00:00:00), the result is 2021-01-10T23:59:00Z. And so on.
It reveals that last() returns the last record not greater than the nearest Sunday 23:59:59.99999 after the range start.
But when I put column argument to the last() function other than default _value everything works as expected.
The aforementioned problem doesn’t run on InfluxDB Cloud 2.0.
