NOW GENERALLY AVAILABLE InfluxDB 3 Core (OSS) and Enterprise. Start fast, scale faster.
Dear team,
I tried to set up an optional string variable but causes a configuration error.
var output_measurement_preffix = string : ‘9010’
The only example I found is related to a lambda datatype as follows: var optional_var = lamba : TRUE
Thank you
var output_measurement_prefix = '9010'
is enough and already a string.
I didn’t explain properly. I am using a template with a json parameter with the values. @Mert this case is a constant. I would like to be a variables from an input file and in case of missing the parameter set a default value.
Best regards
