After adding the following line to the kapacitor.conf file under [[httppost]] section, I could not start kapacitor
alert-template-file = “C:\Mypath\to\Kapacitor\Data\template\alert.html”
Error message:
2020/04/08 13:02:34 Using configuration at: kapacitor.conf
run: create server: invalid configuration: httppost: must use an absolute path for alert-template-file.
To generate a valid configuration file runkapacitord config > kapacitor.generated.conf.
I’m running Windows system
Ganendran
