I am using the versions I wrote above, all services are working properly, I define an alert rule from the interface, for sending messages to the slack channel, but although I enter the values and other information correctly, the alerts do not reach the slack channel, I tested the slack channel url, there is no problem, the test message goes, but as I said, it does not send alarms for the values I specified.
I would like your help about this issue, thank you.
Hello @Cem_Kiyanc,
Unfortunately we don’t offer a lot of support for kapacitor anymore. Your best bet is to reach out to other users who have posted about kapacitor recently for help. I’m sorry.
I might also suggest trying out influxdbv3 and the the python processing engine:
