Hi there,
I’m testing Kapacitor and am currently using ot to push messages from MQTT to Elastic.
In general, it’s working fine, but I have noticed that some fields are missing in Elastic, I’m not sure why this happens though.
I’ve created a sample here: 0_input_mqtt.json · GitHub
As you can see the “gtw_id” is present in the MQTT input JSON, but missing in the elastic data.
Can anyone tell me why this happens and how to fix it?
Thanks for your help!
Edit: I just noticed that those are the string fields - however, how do I specify the gtw_id if it’s inside of an array without using the index (as I want to add all of them)?
