I have data flowing into a dashboard represented in a table and couple gauge charts. I tried to setup an alert for one of the values to fire if it goes above a threshold. It does not seem to fire even after testing with different values and 0 values as well.
Can you show us the query that is being run?
dg
Thanks for responding.
var db = ‘testDB’
var rp = ‘default’
var measurement = ‘ops_message_data’
var groupBy = []
var whereFilter = lambda: TRUE
var name = 'DASH-TEST ’
var idVar = name
var message = ‘Consumer Group:{{ index .Fields “consumer_group” }}’
var idTag = ‘alertID’
var levelTag = ‘level’
var messageField = ‘message’
var durationField = ‘duration’
var outputDB = ‘chronograf’
var outputRP = ‘autogen’
var outputMeasurement = ‘alerts’
var triggerType = ‘threshold’
var details = ‘The consumer group lag has exceeded reasonable limit.
var crit = 100
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
|eval(lambda: “lag”)
.as(‘value’)
var trigger = data
|alert()
.crit(lambda: “value” > crit)
.message(message)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
.details(details)
.stateChangesOnly()
.email()
.to(‘admin@management.com’)
.to(‘support@management.com’)
trigger
|eval(lambda: float(“value”))
.as(‘value’)
.keep()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag(‘alertName’, name)
.tag(‘triggerType’, triggerType)
That is the tickScript. The actual query is the following:
SELECT "lag" FROM "testDB"."default"."ops_message_data" WHERE time > now() - 30m AND "consumer_group"='firehose.transform' AND "messageType"='POST' GROUP BY "consumer_group"
This data is tagged to a dashboard gauge graph
Please, really need help with this. Any ideas as to why this does not work.
Hi ,
the output of the following may help …
the data collection interval in telegraf
select count(*) from “testDB”.“default”.ops_message_data
wait for 10 seconds and do the same statement again
kapacitor stats ingress |grep ops_message_data
kapacitor show DASH-TEST
kapacitor record stream -task DASH-TEST -duration 60s
kapacitor list recordings
best regards ,
Marc
Sorry for the very delayed response:
I did the first 2 and the result was the same. kapacitor show DASH-TEST did not work. I gather that you are trying to gauge whether the data is frequently changing or not? Any other ideas I could try?
