I created a realative alert which should trigger when current value - past value >15.
But I am not getting any alert. Threshold and deadman alert are working fine. I have tried almost several conditions that should have resulted in alert but wasn’t successful.
var db = 'ashish'
var rp = 'autogen'
var measurement = 'test3'
var groupBy = []
var whereFilter = lambda: TRUE
var name = 'test3 alert'
var idVar = name
var message = 'test 3 alert'
var idTag = 'alertID'
var levelTag = 'level'
var messageField = 'message'
var outputDB = 'chronograf'
var outputRP = 'autogen'
var outputMeasurement = 'alerts'
var triggerType = 'relative'
var shift = 1m
0s
var crit = 15
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
|eval(lambda: "new")
.as('value')
var past = data
|shift(shift)
var current = data
var trigger = past
|join(current)
.as('past', 'current')
|eval(lambda: float("current.value" - "past.value"))
.keep()
.as('value')
|alert()
.crit(lambda: "value" > crit)
.message(message)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
.stateChangesOnly()
.slack()
.channel('TestGrafanaAlerts')
trigger
|eval(lambda: float("value"))
.as('value')
.keep()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag('alertName', name)
trigger
|httpOut('output')
