I have a data source sending a stream of json objects over TCP. Should mention that they are separated by carriage return (one json object per line).
i was trying to use a TCP socket_listener with json_v2 to parse the objects, but it seems that they are not getting processed (I don’t see errors either).
if I do the same stream in a file, I get errors from the file listener if I have more than one json object in the file.
Is this possible with socket_listener TCP and json_v2?
