Hello everyone,
I’m trying to split a JSON object with a list of objects using the json_v2 parser, but I’m having problems. I would like to have the tags and the fields and the timestamp separated. Unfortunately, the documentation doesn’t help me much. It is the same data format as the JSON output batch format.
Here is an example:
{"metrics":[{"fields":{"usage_idle":99.74489795894881,"usage_iowait":0,"usage_system":0.2551020407959661,"usage_user":0},"name":"cpu","tags":{"_in":"HostLoadsProd","cpu":"cpu-total","host":"test"},"timestamp":1704724909},{"fields":{"usage_idle":99.57173447496905,"usage_iowait":0,"usage_system":0.2141327623207242,"usage_user":0},"name":"cpu","tags":{"_in":"HostLoadsProd","cpu":"cpu-total","host":"test"},"timestamp":1704724910},{"fields":{"usage_idle":99.74999999976717,"usage_iowait":0,"usage_system":0.25000000000545697,"usage_user":0},"name":"cpu","tags":{"_in":"HostLoadsProd","cpu":"cpu-total","host":"test"},"timestamp":1704724911},{"fields":{"usage_idle":99.44237918380115,"usage_iowait":0,"usage_system":0.18587360595185173,"usage_user":0.3717472118952509},"name":"cpu","tags":{"_in":"HostLoadsProd","cpu":"cpu-total","host":"test"},"timestamp":1704724912},{"fields":{"usage_idle":100,"usage_iowait":0,"usage_system":0,"usage_user":0},"name":"cpu","tags":{"_in":"HostLoadsProd","cpu":"cpu-total","host":"test"},"timestamp":1704724913},{"fields":{"usage_idle":99.66329966298292,"usage_iowait":0,"usage_system":0.16835016834011543,"usage_user":0},"name":"cpu","tags":{"_in":"HostLoadsProd","cpu":"cpu-total","host":test"},"timestamp":1704724914},{"fields":{"usage_idle":99.3464052281614,"usage_iowait":0,"usage_system":0.3267973856220806,"usage_user":0},"name":"cpu","tags":{"_in":"HostLoadsProd","cpu":"cpu-total","host":"test"},"timestamp":1704724915},{"fields":{"usage_idle":99.70282317951438,"usage_iowait":0,"usage_system":0.1485884101076665,"usage_user":0.14858841010090948},"name":"cpu","tags":{"_in":"HostLoadsProd","cpu":"cpu-total","host":"test"},"timestamp":1704724916},{"fields":{"usage_idle":100,"usage_iowait":0,"usage_system":0,"usage_user":0},"name":"cpu","tags":{"_in":"HostLoadsProd","cpu":"cpu-total","host":"test"},"timestamp":1704724917},{"fields":{"usage_idle":99.53703703661286,"usage_iowait":0,"usage_system":0.46296296296608197,"usage_user":0},"name":"cpu","tags":{"_in":"HostLoadsProd","cpu":"cpu-total","host":test"},"timestamp":1704724918}]}
