I have to collect a date from http in JSON, in this format: “2019-08-17T20:36:42.217Z”
I tried json_time_format = "2006-01-02T15:04:05.000Z" but this didn’t work (error '… JSON time key could not be found).
What should I use?
What should I use?
Did you also provide the JSON key to use with json_time_key?
Yes. It’s working now. I didn’t realize the time key was nested inside a key ‘result’ that holds most of the JSON data. It was necessary to set json_query = "result".
Thanks though and sorry for the false alarm.
Hi, can I ask for help?
I have the same issue like topic starter and everything is workin fine when I use json_query, but I need to colect other filds at the same time, so I try to remove json_query option and try to chenge json_time_key like on example
My data is:
"id": "2wjdsnfononapniYGYUIVTDLPOMPOMNtGE",
"storageDaily": [
"atRestTotal": 105020853928250.53,
"intervalStart": "2020-07-01T00:00:00Z"
"atRestTotal": 97803640962687.75,
"intervalStart": "2020-07-02T00:00:00Z"
"atRestTotal": 82941342808224.38,
"intervalStart": "2020-07-03T00:00:00Z"
"atRestTotal": 135553439405527.77,
"intervalStart": "2020-07-04T00:00:00Z"
"atRestTotal": 93394478652852.55,
"intervalStart": "2020-07-05T00:00:00Z"
"atRestTotal": 115175935259697.42,
"intervalStart": "2020-07-06T00:00:00Z"
"atRestTotal": 96535668880984.33,
"intervalStart": "2020-07-07T00:00:00Z"
"atRestTotal": 89280809881294.14,
"intervalStart": "2020-07-08T00:00:00Z"
"atRestTotal": 122059980269958.28,
"intervalStart": "2020-07-09T00:00:00Z"
"atRestTotal": 75410226699755.14,
"intervalStart": "2020-07-10T00:00:00Z"
"atRestTotal": 95104395212054.72,
"intervalStart": "2020-07-11T00:00:00Z"
"atRestTotal": 60070639592999.3,
"intervalStart": "2020-07-12T00:00:00Z"
"bandwidthDaily": [
"egress": {
"repair": 7422539776,
"audit": 28928,
"usage": 354816
"ingress": {
"repair": 852929536,
"usage": 359680
"delete": 0,
"egress": {
"repair": 9654713600,
"audit": 77056,
"usage": 0
"ingress": {
"repair": 23954176,
"usage": 0
"delete": 0,
"egress": {
"repair": 10390602752,
"audit": 78080,
"usage": 7372800
"ingress": {
"repair": 1740841472,
"usage": 5478400
"delete": 0,
"egress": {
"repair": 10921374208,
"audit": 80384,
"usage": 4993536
"ingress": {
"repair": 2209147136,
"usage": 7799808
"delete": 0,
"egress": {
"repair": 10476259328,
"audit": 66560,
"usage": 0
"ingress": {
"repair": 4638720,
"usage": 0
"delete": 0,
"egress": {
"repair": 10697145856,
"audit": 67328,
"usage": 0
"ingress": {
"repair": 9277440,
"usage": 512
"delete": 0,
"egress": {
"repair": 9048644352,
"audit": 56832,
"usage": 256
"ingress": {
"repair": 92774400,
"usage": 1024
"delete": 0,
"egress": {
"repair": 8459767552,
"audit": 58624,
"usage": 11443386112
"ingress": {
"repair": 1009715712,
"usage": 7793152
"delete": 0,
"egress": {
"repair": 7391316736,
"audit": 45568,
"usage": 27907864320
"ingress": {
"repair": 397639680,
"usage": 1536
"delete": 0,
"egress": {
"repair": 7525562880,
"audit": 52224,
"usage": 26752089856
"ingress": {
"repair": 30324736,
"usage": 512
"delete": 0,
"egress": {
"repair": 7841404416,
"audit": 48384,
"usage": 26051842816
"ingress": {
"repair": 870882304,
"usage": 6220288
"delete": 0,
"egress": {
"repair": 4912121600,
"audit": 38400,
"usage": 18134281728
"ingress": {
"repair": 0,
"usage": 0
"delete": 0,
"storageSummary": 1168351411554286.2,
"bandwidthSummary": 222314117888,
"egressSummary": 215044337664,
"ingressSummary": 7269780224,
"audit": {
"totalCount": 25299,
"successCount": 25294,
"alpha": 19.99999999999995,
"beta": 0,
"unknownAlpha": 19.99999999999995,
"unknownBeta": 3.680563825979579e-307,
"score": 1,
"unknownScore": 1
"uptime": {
"totalCount": 28971,
"successCount": 28965,
"alpha": 0,
"beta": 0,
"unknownAlpha": 0,
"unknownBeta": 0,
"score": 0,
"unknownScore": 0
"priceModel": {
"EgressBandwidth": 2000,
"RepairBandwidth": 1000,
"AuditBandwidth": 1000,
"DiskSpace": 150
"nodeJoinedAt": "2020-02-11T16:18:51.907206Z"
I need to parse “storageDaily” and “bandwidthDaily” with json_time_key and all other fields, but I stuck with “JSON time key could not be found”
When I set:
json_query = "storageDaily"
json_time_key = "intervalStart"
json_time_format = "2006-01-02T15:04:05Z"
Everything is working fine, but all other fields are dropping.
When I set:
#json_query = "storageDaily"
json_time_key = "storageDaily_intervalStart"
I got this error: JSON time key could not be found
Could you please point me in the right direction?
