@cnbnjn JSON arrays don’t have keys. To reference elements of an array, you reference the index of the element. So, let’s say to get the first value in the array, GJSON query path would be:
Hi Scott, thanks a lot for your answer.
That will work perfectly fine if the number of elements is always the same.
Any chance to work with an object, so I can read all the elements, even if the number would not always be the same?
