I have two table streams
one (left) is
table
_value
source_ip
0
5
15.185.142.23
0
3
15.185.200.105
another (right) is
table
_measurement
_start
_stop
_time
host
path
source_country
source_ip
0
tail
2023-07-06T05:44:21.844Z
2023-07-06T05:59:21.844Z
2023-07-06T05:45:06.437Z
3532c312ea2e
/firewall/log/untrust-2-trust.log
BH
15.185.142.23
try to join two tables stream with following flux
join.left(
left: leftdata,
right: rightdata,
on: (l, r) => l.source_ip == r.source_ip,
as: (l, r) => ({C: r.source_country,IP:l.source_ip}),
but can not get anything, should be retrun country information, is there problem? thanks
table
C
IP
0
15.185.142.23
d60
July 6, 2023, 9:00am
2
Hey, make sure that group keys are equals for both measurements.
join.left(
left: leftdata |> group(),
right: rightdata |> group(),
Hi guys,
thanks, as this suggestion, can get source_country value, but join result amount is not right. My leftdata amount is 5 with different source_ip, rightdata amount is more than 5, and has same source_ip. I used left.inner, but still is not right. can you give me suggestion, how to fix it? and about group key, I am not sure how to check group keys?
d60
July 7, 2023, 6:22am
4
Hey,
Look at the following example prepared for u:
import "array"
import "join"
left =
array.from(
rows: [
{source_ip: "A", _value: 5,},
{source_ip: "B", _value: 6},
right =
array.from(
rows: [
{source_ip: "A", source_country: "IT", host: "host3", extra: 121.2},
{source_ip: "C", source_country: "GER", host: "host4", extra: 234.3},
join.inner(
left: left |> group(columns: ["source_ip"]),
right: right |> group(columns: ["source_ip"]),
as: (l, r) => ({r with dataFromLeft: l._value}),
In general: group your data for left and right streams to have matchin group keys, and decide which stream you want to keep or extend from the other stream. Use ‘with’ keyword to extend the selected stream from coulms from the other one. Make sure that column names are not overwritten.
I hope it helps!
Join types: Join data with Flux | Flux 0.x Documentation
Join().as parameter: Join data with Flux | Flux 0.x Documentation
Group keys: Group data in InfluxDB with Flux | InfluxDB Cloud (TSM) Documentation
tbs575
July 18, 2023, 4:23am
5
Hi d60,
thanks your reply. actully the right stream like this
right =
array.from(
rows: [
{source_ip: "A", source_country: "GER", host: "host4", extra: 221.3},
I just want keep source_ip
and source_country
. and as your join, the will be generated duplication record
@d60 and @tbs575 ,
Thanks for helping each other out! I really appreciate your contribution to the community.
