I am a newborn to influxDB world, my first challenge is to use
— jMeter Backend Listener @InfluxdbBackendListenerClient – with influxDB UDP protocol
my influxDb is listening on 8086 and my .conf file has UDP enabled
[[udp]]
enabled = true
bind-address = ":8089"
database = "jmeterLocal"
retention-policy = “”
Q1. Do i need to reconfigure influxDB to listen to port 8089 or i can change UDP bind-address to 8086?
Q2. on the jMeter side … InfluxdbBackendListenerClient requires InfluxdbURL … should it be 8086?
i set influxdbMatricsSender to “org.apache.jmeter.visualizers.backend.influxdb.UdpMetricsSender” which throws following exception
Caused by: java.lang.ClassNotFoundException: org.apache.jmeter.visualizers.backend.influxdb.udpMetricsSender
at java.net.URLClassLoader.findClass(URLClassLoader.java:381) ~[?:1.8.0_152]
at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_152]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_152]
at java.lang.Class.forName0(Native Method) ~[?:1.8.0_152]
at java.lang.Class.forName(Class.java:264) ~[?:1.8.0_152]
at org.apache.jmeter.visualizers.backend.influxdb.InfluxdbBackendListenerClient.setupTest(InfluxdbBackendListenerClient.java:321) ~[ApacheJMeter_components.jar:3.3 r1808647]
at org.apache.jmeter.visualizers.backend.BackendListener.testStarted(BackendListener.java:345) ~[ApacheJMeter_components.jar:3.3 r1808647]
… 4 more
