Hello
I’ve configured the " influxdb_v2_listener" to listen on 8081. It appears to work fine when the Telegraf container starts.
The container logs confirm that too
2022-02-04T20:40:57Z I! [inputs.socket_listener] Listening on udp://[::]:25826
2022-02-04T20:40:57Z I! [inputs.influxdb_v2_listener] Started HTTP listener service on :8081
The Telegraf container is attached to the “host” network
However, if I run “curl http://192.168.0.100:8081” I get 404 not found
If I do the same to 25826 I get
curl: (7) Failed to connect to 192.168.0.100 port 25826: Connection refused
Running “docker ps” does not show the container as exposing any ports.
What am I doing wrong or is this some kind of bug?
I am using the listener to relay metrics from Traefik to influxdb v2 and it keeps reporting 404 not found every 10 seconds
Thank you in advance
