SIGQUIT: quit
PC=0x45d4b3 m=2 sigcode=0
goroutine 0 [idle]:
runtime.futex(0x1e89db8, 0x0, 0x7f094118ad68, 0x0, 0x7f0900000000, 0x45d146, 0x3c, 0x0, 0x7f094118adb0, 0x4105e0, …)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/sys_linux_amd64.s:423 +0x23
runtime.futexsleep(0x1e89db8, 0x0, 0xdf8475800)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/os_linux.go:62 +0xd7
runtime.notetsleep_internal(0x1e89db8, 0xdf8475800, 0x0)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/lock_futex.go:174 +0xd0
runtime.notetsleep(0x1e89db8, 0xdf8475800, 0x3c939216c4301)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/lock_futex.go:194 +0x56
runtime.sysmon()
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/proc.go:3805 +0x135
runtime.mstart1()
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/proc.go:1179 +0x11e
runtime.mstart()
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/proc.go:1149 +0x64
goroutine 1 [semacquire, 354 minutes]:
sync.runtime_Semacquire(0xc4201f089c)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/sema.go:47 +0x34
sync.(*WaitGroup).Wait(0xc4201f0890)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/sync/waitgroup.go:131 +0x7a
github.com/influxdata/telegraf/agent.(*Agent).Run(0xc4201dc018, 0xc420064540, 0x0, 0x0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:430 +0x4ed
main.reloadLoop(0xc420064ae0, 0x1eacbb0, 0x0, 0x0, 0x1eacbb0, 0x0, 0x0, 0x1eacbb0, 0x0, 0x0, …)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/cmd/telegraf/telegraf.go:231 +0xa46
main.main()
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/cmd/telegraf/telegraf.go:408 +0x65b
goroutine 17 [syscall, 354 minutes, locked to thread]:
runtime.goexit()
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/asm_amd64.s:2197 +0x1
goroutine 6 [syscall, 354 minutes]:
os/signal.signal_recv(0x0)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/sigqueue.go:116 +0x104
os/signal.loop()
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/os/signal/signal_unix.go:22 +0x22
created by os/signal.init.1
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/os/signal/signal_unix.go:28 +0x41
goroutine 6223 [chan send, 172 minutes]:
github.com/influxdata/telegraf/agent.(*accumulator).AddCounter(0xc4200b7060, 0x1534ec8, 0x4, 0xc4204162d0, 0x0, 0x0, 0x0, 0x0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/accumulator.go:75 +0x12e
github.com/influxdata/telegraf/plugins/inputs/system.(*SwapStats).Gather(0xc4201c48b0, 0x1da4ec0, 0xc4200b7060, 0xc42005d620, 0x762d5a)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/system/memory.go:71 +0x5a1
github.com/influxdata/telegraf/agent.gatherWithTimeout.func1(0xc420641c20, 0xc42015c380, 0xc4200b7060)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:153 +0x49
created by github.com/influxdata/telegraf/agent.gatherWithTimeout
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:154 +0xcc
goroutine 26 [select, 354 minutes, locked to thread]:
runtime.gopark(0x15bf330, 0x0, 0x1537f6a, 0x6, 0x18, 0x2)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/proc.go:271 +0x13a
runtime.selectgoImpl(0xc420030f50, 0x0, 0x18)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/select.go:423 +0x1364
runtime.selectgo(0xc420030f50)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/select.go:238 +0x1c
runtime.ensureSigM.func1()
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/signal_unix.go:434 +0x2dd
runtime.goexit()
goroutine 4486 [semacquire, 232 minutes]:
sync.runtime_notifyListWait(0xc4201c6090, 0xc4000009ea)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/sema.go:297 +0x10b
sync.(*Cond).Wait(0xc4201c6080)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/sync/cond.go:57 +0x89
github.com/eclipse/paho.mqtt.golang.keepalive.func4(0xc4206ddb70, 0xc420193c00, 0xc4206e2a20, 0xc4206fe1e0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/ping.go:86 +0x7d
created by github.com/eclipse/paho.mqtt.golang.keepalive
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/ping.go:96 +0x41e
goroutine 21 [select, 354 minutes]:
github.com/eclipse/paho.mqtt.golang.(*router).matchAndDispatch.func1(0xc420064480, 0xc420016940, 0xc420111b01, 0xc420193c00)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/router.go:134 +0x545
created by github.com/eclipse/paho.mqtt.golang.(*router).matchAndDispatch
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/router.go:160 +0x5c
goroutine 4617 [chan send, 214 minutes]:
github.com/eclipse/paho.mqtt.golang.(*client).Publish(0xc420193c00, 0xc420286380, 0x6b, 0xc4202a0000, 0x12b3dc0, 0xc4202a6800, 0x12ca6e0, 0xc42027c3c0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/client.go:520 +0x614
github.com/influxdata/telegraf/plugins/outputs/mqtt.(*MQTT).publish(0xc4200f6000, 0xc420286380, 0x6b, 0xc4201ff200, 0x532, 0x600, 0x0, 0x0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/outputs/mqtt/mqtt.go:154 +0x239
github.com/influxdata/telegraf/plugins/outputs/mqtt.(*MQTT).Write(0xc4200f6000, 0xc4202eab00, 0x58, 0x58, 0x0, 0x0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/outputs/mqtt/mqtt.go:143 +0x329
github.com/influxdata/telegraf/internal/models.(*RunningOutput).write(0xc4201ca000, 0xc4202eab00, 0x58, 0x58, 0x0, 0x0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/internal/models/running_output.go:179 +0x10c
github.com/influxdata/telegraf/internal/models.(*RunningOutput).Write(0xc4201ca000, 0x15bf460, 0xc4202a2f00)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/internal/models/running_output.go:161 +0x497
github.com/influxdata/telegraf/agent.(*Agent).flush.func1(0xc4202a2f00, 0xc4201ca000)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:238 +0x59
created by github.com/influxdata/telegraf/agent.(*Agent).flush
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:243 +0xa5
goroutine 4616 [semacquire, 226 minutes]:
sync.runtime_Semacquire(0xc4202a2f0c)
sync.(*WaitGroup).Wait(0xc4202a2f00)
github.com/influxdata/telegraf/agent.(*Agent).flush(0xc4201dc018)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:246 +0xd9
github.com/influxdata/telegraf/agent.(*Agent).flusher.func3(0xc4202f61e0, 0xc4201dc018, 0xc420064540)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:338 +0x7f
created by github.com/influxdata/telegraf/agent.(*Agent).flusher
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:345 +0x2a6
goroutine 4485 [semacquire, 232 minutes]:
sync.runtime_notifyListWait(0xc4201c6050, 0xc4000000da)
sync.(*Cond).Wait(0xc4201c6040)
github.com/eclipse/paho.mqtt.golang.keepalive.func3(0xc4206ddb70, 0xc420193c00, 0xc4206e2a20, 0xc4206fe220, 0x737be7600)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/ping.go:70 +0x7d
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/ping.go:80 +0x3d5
goroutine 36 [select, 354 minutes]:
main.reloadLoop.func1(0xc4200645a0, 0xc420064540, 0xc420265180, 0xc420064ae0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/cmd/telegraf/telegraf.go:192 +0x24a
created by main.reloadLoop
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/cmd/telegraf/telegraf.go:206 +0x6ec
goroutine 37 [chan send, 176 minutes]:
github.com/influxdata/telegraf/agent.(*Agent).flusher(0xc4201dc018, 0xc420064540, 0xc42005d200, 0xc42005d260, 0x458abc, 0x180001)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:354 +0x408
github.com/influxdata/telegraf/agent.(*Agent).Run.func1(0xc4201f0890, 0xc4201dc018, 0xc420064540, 0xc42005d200, 0xc42005d260)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:400 +0x7a
created by github.com/influxdata/telegraf/agent.(*Agent).Run
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:404 +0x316
goroutine 38 [select]:
github.com/influxdata/telegraf/agent.gatherWithTimeout(0xc420064540, 0xc42015c380, 0xc4200b7060, 0xdf8475800)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:157 +0x28f
github.com/influxdata/telegraf/agent.(*Agent).gatherer(0xc4201dc018, 0xc420064540, 0xc42015c380, 0xdf8475800, 0xc42005d200)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:124 +0x2ad
github.com/influxdata/telegraf/agent.(*Agent).Run.func3(0xc4201f0890, 0xc4201dc018, 0xc420064540, 0xc42005d200, 0xc42015c380, 0xdf8475800)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:426 +0x7d
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:427 +0x4a4
goroutine 39 [select]:
github.com/influxdata/telegraf/agent.gatherWithTimeout(0xc420064540, 0xc42015c400, 0xc420353a40, 0xdf8475800)
github.com/influxdata/telegraf/agent.(*Agent).gatherer(0xc4201dc018, 0xc420064540, 0xc42015c400, 0xdf8475800, 0xc42005d200)
github.com/influxdata/telegraf/agent.(*Agent).Run.func3(0xc4201f0890, 0xc4201dc018, 0xc420064540, 0xc42005d200, 0xc42015c400, 0xdf8475800)
goroutine 40 [select]:
github.com/influxdata/telegraf/agent.gatherWithTimeout(0xc420064540, 0xc42015c480, 0xc4200b6620, 0xdf8475800)
github.com/influxdata/telegraf/agent.(*Agent).gatherer(0xc4201dc018, 0xc420064540, 0xc42015c480, 0xdf8475800, 0xc42005d200)
github.com/influxdata/telegraf/agent.(*Agent).Run.func3(0xc4201f0890, 0xc4201dc018, 0xc420064540, 0xc42005d200, 0xc42015c480, 0xdf8475800)
goroutine 41 [select]:
github.com/influxdata/telegraf/agent.gatherWithTimeout(0xc420064540, 0xc42015c500, 0xc4202ac160, 0xdf8475800)
github.com/influxdata/telegraf/agent.(*Agent).gatherer(0xc4201dc018, 0xc420064540, 0xc42015c500, 0xdf8475800, 0xc42005d200)
github.com/influxdata/telegraf/agent.(*Agent).Run.func3(0xc4201f0890, 0xc4201dc018, 0xc420064540, 0xc42005d200, 0xc42015c500, 0xdf8475800)
goroutine 42 [select]:
github.com/influxdata/telegraf/agent.gatherWithTimeout(0xc420064540, 0xc42015c580, 0xc4202ac3e0, 0xdf8475800)
github.com/influxdata/telegraf/agent.(*Agent).gatherer(0xc4201dc018, 0xc420064540, 0xc42015c580, 0xdf8475800, 0xc42005d200)
github.com/influxdata/telegraf/agent.(*Agent).Run.func3(0xc4201f0890, 0xc4201dc018, 0xc420064540, 0xc42005d200, 0xc42015c580, 0xdf8475800)
goroutine 43 [select]:
github.com/influxdata/telegraf/agent.gatherWithTimeout(0xc420064540, 0xc42015c640, 0xc4202ac640, 0xdf8475800)
github.com/influxdata/telegraf/agent.(*Agent).gatherer(0xc4201dc018, 0xc420064540, 0xc42015c640, 0xdf8475800, 0xc42005d200)
github.com/influxdata/telegraf/agent.(*Agent).Run.func3(0xc4201f0890, 0xc4201dc018, 0xc420064540, 0xc42005d200, 0xc42015c640, 0xdf8475800)
goroutine 44 [select]:
github.com/influxdata/telegraf/agent.gatherWithTimeout(0xc420064540, 0xc42015c700, 0xc420360ee0, 0xdf8475800)
github.com/influxdata/telegraf/agent.(*Agent).gatherer(0xc4201dc018, 0xc420064540, 0xc42015c700, 0xdf8475800, 0xc42005d200)
github.com/influxdata/telegraf/agent.(*Agent).Run.func3(0xc4201f0890, 0xc4201dc018, 0xc420064540, 0xc42005d200, 0xc42015c700, 0xdf8475800)
goroutine 65 [semacquire, 180 minutes]:
sync.runtime_SemacquireMutex(0xc4201ca09c)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/sema.go:62 +0x34
sync.(*Mutex).Lock(0xc4201ca098)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/sync/mutex.go:87 +0x9d
github.com/influxdata/telegraf/internal/models.(*RunningOutput).write(0xc4201ca000, 0xc420614000, 0x3e8, 0x3e8, 0x0, 0x0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/internal/models/running_output.go:176 +0x77
github.com/influxdata/telegraf/internal/models.(*RunningOutput).AddMetric(0xc4201ca000, 0x1da86a0, 0xc4206f5b00)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/internal/models/running_output.go:119 +0x14c
github.com/influxdata/telegraf/agent.(*Agent).flusher.func1(0xc4201f19c0, 0xc420064540, 0xc4202f6120, 0xc4201dc018)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:284 +0x1e5
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:292 +0xe5
goroutine 47 [select]:
gopkg.in/mgo%2ev2.(*mongoCluster).syncServersLoop(0xc42000ad00)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/gopkg.in/mgo.v2/cluster.go:394 +0x3a3
created by gopkg.in/mgo%2ev2.newCluster
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/gopkg.in/mgo.v2/cluster.go:78 +0x188
goroutine 6237 [chan send, 170 minutes]:
github.com/influxdata/telegraf/agent.(*accumulator).AddGauge(0xc420353a40, 0x15349e8, 0x4, 0xc4204163f0, 0xc4204163c0, 0x0, 0x0, 0x0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/accumulator.go:64 +0x12e
github.com/influxdata/telegraf/plugins/inputs/system.(*DiskStats).Gather(0xc42005c240, 0x1da4ec0, 0xc420353a40, 0x12bdbe0, 0xc42005db60)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/system/disk.go:79 +0xa4c
github.com/influxdata/telegraf/agent.gatherWithTimeout.func1(0xc4205f24e0, 0xc42015c400, 0xc420353a40)
goroutine 31 [sleep]:
time.Sleep(0x37e11d600)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/time.go:59 +0xf9
gopkg.in/mgo%2ev2.(*mongoServer).pinger(0xc420250380, 0x1)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/gopkg.in/mgo.v2/server.go:301 +0x293
created by gopkg.in/mgo%2ev2.newServer
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/gopkg.in/mgo.v2/server.go:89 +0x166
goroutine 33 [IO wait]:
net.runtime_pollWait(0x7f09418f30b8, 0x72, 0xb)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/runtime/netpoll.go:164 +0x59
net.(*pollDesc).wait(0xc420286298, 0x72, 0x1d911a0, 0x1d878d0)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/net/fd_poll_runtime.go:75 +0x38
net.(*pollDesc).waitRead(0xc420286298, 0xc420263800, 0x24)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/net/fd_poll_runtime.go:80 +0x34
net.(*netFD).Read(0xc420286230, 0xc420263800, 0x24, 0x24, 0x0, 0x1d911a0, 0x1d878d0)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/net/fd_unix.go:250 +0x1b7
net.(*conn).Read(0xc42000e0a0, 0xc420263800, 0x24, 0x24, 0x0, 0x0, 0x0)
/build/mts/release/sb-15299446/compcache/cayman_go/ob-6134445/linux64/lin64/src/net/net.go:181 +0x70
gopkg.in/mgo%2ev2.fill(0x1da5a00, 0xc42000e0a0, 0xc420263800, 0x24, 0x24, 0x0, 0x11)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/gopkg.in/mgo.v2/socket.go:535 +0x53
gopkg.in/mgo%2ev2.(*mongoSocket).readLoop(0xc420250460)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/gopkg.in/mgo.v2/socket.go:551 +0x107
created by gopkg.in/mgo%2ev2.newSocket
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/gopkg.in/mgo.v2/socket.go:194 +0x259
goroutine 66 [select, 354 minutes]:
github.com/influxdata/telegraf/agent.(*Agent).flusher.func2(0xc4201f19c0, 0xc420064540, 0xc42005d260, 0xc4201dc018)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:298 +0x358
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/agent.go:321 +0x14b
goroutine 4463 [semacquire, 232 minutes]:
sync.runtime_Semacquire(0xc4206ddb7c)
sync.(*WaitGroup).Wait(0xc4206ddb70)
github.com/eclipse/paho.mqtt.golang.keepalive.func1(0xc4206e2a20, 0xc420193c00, 0xc4206ddb70)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/ping.go:36 +0x7c
github.com/eclipse/paho.mqtt.golang.keepalive(0xc420193c00)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/ping.go:102 +0x902
created by github.com/eclipse/paho.mqtt.golang.(*client).reconnect
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/client.go:348 +0x8ab
goroutine 6248 [semacquire, 170 minutes]:
sync.runtime_Semacquire(0xc4201c441c)
sync.(*WaitGroup).Wait(0xc4201c4410)
github.com/influxdata/telegraf/plugins/inputs/mongodb.(*MongoDB).Gather(0xc420276000, 0x1da4ec0, 0xc4202ac160, 0xc42005dc80, 0x762d5a)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/mongodb/mongodb.go:103 +0x250
github.com/influxdata/telegraf/agent.gatherWithTimeout.func1(0xc4203707e0, 0xc42015c500, 0xc4202ac160)
goroutine 6250 [chan send, 170 minutes]:
github.com/influxdata/telegraf/agent.(*accumulator).AddGauge(0xc4202ac3e0, 0x1533d86, 0x3, 0xc4202e41b0, 0xc4202e4180, 0xc4206fe600, 0x1, 0x1)
github.com/influxdata/telegraf/plugins/inputs/system.(*CPUStats).Gather(0xc420274060, 0x1da4ec0, 0xc4202ac3e0, 0xc42005dc80, 0x762d5a)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/system/cpu.go:122 +0xfb1
github.com/influxdata/telegraf/agent.gatherWithTimeout.func1(0xc4203708a0, 0xc42015c580, 0xc4202ac3e0)
goroutine 6224 [chan send, 172 minutes]:
github.com/influxdata/telegraf/agent.(*accumulator).AddCounter(0xc4202ac640, 0x1533e8e, 0x3, 0xc420416300, 0x0, 0x0, 0x0, 0x0)
github.com/influxdata/telegraf/plugins/inputs/system.(*MemStats).Gather(0xc4201c4c40, 0x1da4ec0, 0xc4202ac640, 0xc42005d0e0, 0x762d5a)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/system/memory.go:39 +0x856
github.com/influxdata/telegraf/agent.gatherWithTimeout.func1(0xc420641da0, 0xc42015c640, 0xc4202ac640)
goroutine 4472 [semacquire, 232 minutes]:
sync.runtime_Semacquire(0xc420193f28)
sync.(*WaitGroup).Wait(0xc420193f1c)
github.com/eclipse/paho.mqtt.golang.(*client).internalConnLost(0xc420193c00, 0x1d8d120, 0xc4207179a0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/client.go:436 +0x7e
created by github.com/eclipse/paho.mqtt.golang.errorWatch
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/net.go:322 +0x242
goroutine 4484 [semacquire, 232 minutes]:
sync.runtime_notifyListWait(0xc4201c6010, 0xc4000000d8)
sync.(*Cond).Wait(0xc4201c6000)
github.com/eclipse/paho.mqtt.golang.keepalive.func2(0xc4206ddb70, 0xc420193c00, 0xc4206e2a20, 0xc4206fe260, 0xc4206fe1e0, 0xc4206fe220, 0x737be7600)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/ping.go:52 +0x7d
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/eclipse/paho.mqtt.golang/ping.go:64 +0x382
goroutine 6206 [chan send, 172 minutes]:
github.com/influxdata/telegraf/agent.(*accumulator).AddCounter(0xc4200b6620, 0x15374f0, 0x6, 0xc4204164b0, 0xc420416480, 0x0, 0x0, 0x0)
github.com/influxdata/telegraf/plugins/inputs/system.(*DiskIOStats).Gather(0xc420286070, 0x1da4ec0, 0xc4200b6620, 0x12bdbe0, 0xc4205f26c0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/system/disk.go:161 +0x922
github.com/influxdata/telegraf/agent.gatherWithTimeout.func1(0xc42005c900, 0xc42015c480, 0xc4200b6620)
goroutine 6249 [chan send, 170 minutes]:
github.com/influxdata/telegraf/agent.(*accumulator).AddFields(0xc4202ac160, 0x1539c7c, 0x7, 0xc4202e4360, 0xc4202e4330, 0xc4206feec0, 0x1, 0x1)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/agent/accumulator.go:53 +0x12e
github.com/influxdata/telegraf/plugins/inputs/mongodb.(*MongodbData).flush(0xc420357da8, 0x1da4ec0, 0xc4202ac160)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/mongodb/mongodb_data.go:160 +0xd5
github.com/influxdata/telegraf/plugins/inputs/mongodb.(*Server).gatherData(0xc4202ac220, 0x1da4ec0, 0xc4202ac160, 0x0, 0x0, 0x0)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/mongodb/mongodb_server.go:110 +0xebd
github.com/influxdata/telegraf/plugins/inputs/mongodb.(*MongoDB).gatherServer(0xc420276000, 0xc4202ac220, 0x1da4ec0, 0xc4202ac160, 0xc42005dc80, 0x762d5a)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/mongodb/mongodb.go:171 +0x89
github.com/influxdata/telegraf/plugins/inputs/mongodb.(*MongoDB).Gather.func1(0xc4201c4410, 0x1da4ec0, 0xc4202ac160, 0xc420276000, 0xc4202ac220)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/mongodb/mongodb.go:99 +0x73
created by github.com/influxdata/telegraf/plugins/inputs/mongodb.(*MongoDB).Gather
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/mongodb/mongodb.go:100 +0x3ec
goroutine 6231 [chan send, 172 minutes]:
github.com/influxdata/telegraf/agent.(*accumulator).AddCounter(0xc420360ee0, 0x1533eb8, 0x3, 0xc4206cd1d0, 0xc4206cd1a0, 0x0, 0x0, 0x0)
github.com/influxdata/telegraf/plugins/inputs/system.(*NetIOStats).Gather(0xc42015c680, 0x1da4ec0, 0xc420360ee0, 0x12bdbe0, 0xc42005db60)
/build/mts/release/sb-15299446/cayman_telegraf/telegraf/src/github.com/influxdata/telegraf/plugins/inputs/system/net.go:89 +0x7c2
github.com/influxdata/telegraf/agent.gatherWithTimeout.func1(0xc42005dda0, 0xc42015c700, 0xc420360ee0)
rax 0xfffffffffffffffc
rbx 0x0
rcx 0xffffffffffffffff
rdx 0x0
rdi 0x1e89db8
rsi 0x0
rbp 0x7f094118ad78
rsp 0x7f094118ad30
r8 0x0
r9 0x0
r10 0x7f094118ad68
r11 0x246
r12 0x0
r13 0x34
r14 0x0
r15 0xf3
rip 0x45d4b3
rflags 0x246
cs 0x33
fs 0x0
gs 0x0
