I’m monitoring java process on several machines, Is there a way to configure check for running process with wildcard*?
Maybe.
Tell us which service check plugin you’re using to do the check with, and we
might have a more definite answer.
Antony.
Right now I’m trying to that with the procstat plugin using the cmdline parmeter.
Sorry, but I can’t easily find that. Please can you provide a URL to the
plugin you are using?
Thanks,
Antony.
Apologies - I think I got your question confused between InfluxDB and Icinga
Please ignore me (for now) and I hope someone else can answer your original
question.
Antony.
