JMU
1
If there is a directory where every X time a new .csv file is generated, can Telegraf read only the new files and write on InfluxDB.
I appreciate the answers and links of examples if it is necessary.
Thanks in advance
Anaisdg
2
Hello @JMU,
You can use the tail plugin to tail an existing CSV.
But for new files I think you’d have to use the execd input plugin and create your own solution
Plugin Spotlight: Exec & Execd | InfluxData.
