I would like to set a tag to my KNX measured values that contains the name of the room. Is this possible somehow? How else can I find out later where the value comes from without first looking up the group address? How do you Deal with it?
Yes, this is exactly what I need in my case. However, I have the problem that the tags do not show up.
## Measurement definition(s)
[[inputs.knx_listener.measurement]]
# ## Name of the measurement
name = "Esszimmer | Temperatur"
# ## Datapoint-Type (DPT) of the KNX messages
dpt = "9.001"
# ## List of Group-Addresses (GAs) assigned to the measurement
addresses = ["7/0/22"]
[inputs.knx_listener.measurement.tags]
location = "Esszimmer"
does the Plugin not Support tags or what i am missing?
[[inputs.knx_listener]]
[inputs.knx_listener.tags]
dpt = "9.001"
brings me to this:
2023-02-19T20:23:44Z E! error loading config file http://influxdb1:8086/api/v2/telegrafs/0ac44e53e3194000: error parsing data: line 153: array table `inputs.knx_listener.measurement' is in conflict with table in line 144
Right, any measurement from that input will get that tag. If you want only certain metrics from a measurement to be assigned a tag, your best bet is to use starlark so you can manage the logic.
