Just like topic. Is influxdb support to do mathematics across several measurements ?
Ex: SELECT ‘a1’ from ‘apple’ + SELECT ‘b1’ from ‘Grape’ + SELECT ‘c1’ from ‘Melon’
It’s not actually capable within influxdb itself, see here. That being said, I think it’s possible using something like grafana to put this together, but it’s not a clean way of doing it.
I’m not near a grafana instance with data at the moment, but will check in the morning and get back to you.
Last resort, pull the data down into a pandas dataframe (or set of frames) with influxdb-python and run the magic there. In terms of visualization, you can write that data back into influxdb itself or just render using bokeh or any other awesome python lib.
It is also possible to create a new measurement containing the result using Kapacitor. Here is a streaming example and a batch example.
