New user here. I’m trying to downsample sensor data from a home assistant instance. The aggregateWindow query built by the query builder throws a runtime error: “invalid memory address or nil point dereference error.” here’s the query:
Blockquote
from(bucket: “home_assistant/autogen”)
|> filter(fn: (r) => r[“_measurement”] == “humidity”
|> filter(fn: (r) => r[“_field”] == “value”)
|> aggregateWindow(every: 1h, fn: mean, createEmpty: true)
raw data looks like this in the same query minus the aggregateWindow function:
Limiting the query to a single sensor makes no difference - still the same error. What am I doing wrong? TIA
