I’m trying to write aggregated result from two measurements into a single measurement.
I found on documentation that you can write multiple matching measurements with :MEASUREMENT keyword in INTO query. Like
SELECT * INTO "copy_NOAA_water_database"."autogen".:MEASUREMENT FROM "NOAA_water_database"."autogen"./.*/
What I’m trying to do is
SELECT mean("water_level") INTO "copy_NOAA_water_database"."autogen"."water_agg" FROM "NOAA_water_database"."autogen"./.*/ GROUP BY time(15m), *
The above query runs successfully, but I’m not sure whether influx has considered points from all measurement of NOAA_water_database or just last appearing measurement is considered.
