Hi, I had to completely (?) uninstall influx from the Raspberry Pi 5 using Bookworm, as I could no longer connect via port 8086. There are a few instructions on the internet for installing influxdb2, but none that helped me. How can I create a proper installation of Influxdb2 using Bookworm? Preferably in a version that still contains the button for csv export.
The problem with csv-export-Button is solved.
The problem with the button for csv export no longer exists, but does anyone know the correct, current and as simple as possible installation instructions for influxdb2?
I hope that I am in the right forum for Influxdata here.
Since no one has responded here, I decided to use one of the solutions offered on the Internet.
Version 2.7.11 is now running.
Please provide a link to the instructions you found which worked, in case
anyone else has the same problem and could benefit from the solution.
Antony.
