I am trying to change the _time column with ‘machine_timestamp’ that I am sending to Telegraf via Eventhub.
Here is a sample of the message I am sending
{‘machine_timestamp’: ‘2024-07-29T14:30:00Z’,
‘measurement’: ‘TEST’,
‘sig’: ‘Temp’,
‘table_name’: ‘High Temp’,
‘value’: 24.93352988307621}
And here is the configuration of my Telegraf
[agent]
collection_jitter = “0s”
debug = true
flush_interval = “1s”
flush_jitter = “0s”
hostname = “”
interval = “1s”
logfile = “”
metric_batch_size = 1000
metric_buffer_limit = 10000
omit_hostname = true
precision = “”
quiet = false
round_interval = true
[[processors.enum]]
[[processors.enum.mapping]]
dest = “status_code”
field = “status”
[processors.enum.mapping.value_mappings]
critical = 3
healthy = 1
problem = 2
[[processors.converter]]
[processors.converter.fields]
float = [
“value”,
“min”,
“max”,
“mean”,
“threesigma”
[[outputs.influxdb_v2]]
bucket = "IFMP"
organization = "organization"
token = "$TOKEN"
urls = [
"https://urll.com"
[[inputs.statsd]]
allowed_pending_messages = 10000
metric_separator = "_"
percentile_limit = 1000
percentiles = [
50.0,
95.0,
99.0
service_address = ":8125"
[[inputs.eventhub_consumer]]
connection_string = "$EH_CONN_STRING"
data_format = "json"
json_time_key = "machine_timestamp"
json_time_format = "RFC3339"
json_string_fields = [
"value",
"min",
"max",
"mean",
"threesigma"
name_override = "Measurement_Name"
tag_keys = [
"sig",
"table_name",
"mountpoint",
"interface"
When I use this config, I see from the logs that telegraf output data to influxDB
2024-07-29T22:08:17Z D! [outputs.influxdb_v2] Wrote batch of 300 metrics in 18.539421ms
but I see no data in influxDB
When I remove the json_time_key and json_time_format lines the data is written, but obviously I am not replacing the _time column value with anything.
How can I insert my own timestamps to influxDB so that they show up under the _time column?
