I’ve been trying to get output from inputs.tail for awhile now and I am at the point where I’m hoping the community can help. I reviewed telegraf/plugins/parsers/grok at master · influxdata/telegraf · GitHub to learn about how the parser works, I then also developed a grok pattern at https://grokdebug.herokuapp.com/ to verify that it is able to parse logs from my system. I am still not getting anything out of telegraf.
Test telegraf.conf
# Read Nginx's basic status information (ngx_http_stub_status_module)
[[inputs.nginx]]
## An array of Nginx stub_status URI to gather stats.
urls = ["http://127.0.0.1/server_status"]
## Optional TLS Config
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
## HTTP response timeout (default: 5s)
response_timeout = "5s"
[[outputs.file]]
files = ["stdout"]
[[inputs.tail]]
name_override = "nginx_access_log"
files = ["/var/log/nginx/access.log"]
from_beginning = true
#pipe = false
#watch_method = "inotify"
data_format = "grok"
grok_patterns = ["%{CUSTOM_LOG}"]
grok_custom_patterns = '''
CUSTOM_LOG %{NOTSPACE:host} %{IPORHOST:client_ip} - \[%{HTTPDATE:ts:ts-httpd}\] "(?:%{WORD:verb:tag} %{NOTSPACE:request}(?: HTTP/%{NUMBER:http_version:float})?|%{DATA:rawrequest})" %{NUMBER:resp_code:tag} %{NUMBER:resp_bytes:int} %{NUMBER:response_time_ns:duration} "%{DATA:referrer}" "%{DATA:agent}"
Example log entry:
git.gec.im 185.191.171.11 - [20/Aug/2022:18:41:33 -0500] "GET /GRMrGecko/CocoaShare/action/star?redirect_to=%2FGRMrGecko%2FCocoaShare%2Fsrc%2Fcommit%2F9ebac37394dbb1f6fda47d01db50f806399348a9%2FResources%2FWebDav%2FWebDavAccountPane.xib HTTP/1.1" 405 0 0.003 "-" "Mozilla/5.0 (compatible; SemrushBot/7~bl; +http://www.semrush.com/bot.html)" "-"
Log configuration in nginx:
log_format main '$http_host $remote_addr - [$time_local] "$request" '
'$status $body_bytes_sent $request_time "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
Test results:
# sudo -u telegraf /usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d --debug --test
2022-08-21T00:56:58Z I! Starting Telegraf 1.23.4
2022-08-21T00:56:58Z I! Loaded inputs: nginx tail
2022-08-21T00:56:58Z I! Loaded aggregators:
2022-08-21T00:56:58Z I! Loaded processors:
2022-08-21T00:56:58Z W! Outputs are not used in testing mode!
2022-08-21T00:56:58Z I! Tags enabled: host=mainserver.gec.im
2022-08-21T00:56:58Z D! [agent] Initializing plugins
2022-08-21T00:56:58Z D! [agent] Starting service inputs
2022-08-21T00:56:58Z D! [agent] Stopping service inputs
2022-08-21T00:56:58Z D! [agent] Input channel closed
> nginx,host=mainserver.gec.im,port=80,server=127.0.0.1 accepts=41290i,active=8i,handled=41290i,reading=0i,requests=85149i,waiting=4i,writing=4i 1661043418000000000
2022-08-21T00:56:58Z D! [agent] Stopped Successfully
I double checked that the telegraf user is able to tail the log file, not sure where to go for debug from here. I thought enabling debug in telegraf would output debug details but it only outputs metrics sent.
