Inputs.jti_openconfig_telemetry sensor per server
I am working with inputs.jti_openconfig_telemetry. In the general configuration, all configured sensors are pulled from all configured servers. I need to have specific sensors configured on per server basis.
You are going to have to provide some additional info to get help. For example, it sounds like you have configured the sensors option. Can you provide what you did and what you expect or are trying to do please?
Hi, I found that I have the option to repeat the plugin with different configuration options, this served what I needed. Thanks.
Great! thanks for following up with your solution
