Inputs.http_response authentication
I need to telegraf test the GET of the following URL:
“http://10.135.98.52:8581/odata/api/interfaces?$select=ID&$filter=((groups/Name eq ‘GRX’))”
The server need a username/pass authentication.
How can I configure the plugin http_response?
I tried something like this:
HTTP/HTTPS request CA ODATA API Test
[[inputs.http_response]]
name_suffix = “_ca_odata”
address = “http://10.135.98.52:8581/odata/api/interfaces?$select=ID&$filter=((groups/Name eq ‘GRX’))”
response_timeout = “5s”
method = “GET”
follow_redirects = false
username = “user”
password = “pass”
BR
DAvid
It depends on the format of the response of http://10.135.98.52:8581/odata/api/interfaces?$select=ID&$filter=((groups/Name eq ‘GRX’)) (open in a browser and paste here if you are unsure). These docs explain what data input formats are supported.
