Inputs.exec module of Telegraf is NOT able to send data in integer form to influx DB
Hello @Ravinder_Singh,
I just wanted to follow up with you, how’s it going?
@Anaisdg, Hi Anaisdg, thank you for follow up here, I believe initial config file setting, which is later provided by you too are working fine. It took me sometime to get the root cause, I will do a write up on how I fixed it kin a day or two and post it here :slight_smile:
THANKS a TON for @Anaisdg helping here, really loved the support I got in forums, you folks ROCK.
Thanks,
R. Singh
