I am trying to monitor an NFS mount with the inputs.exec plugin.
Script i’m running:
#!/bin/bash
#echo "["
#du -ks "$@" | awk '{if (NR!=1) {printf ",\n"};printf " { \"directory_size_kilobytes\": "$1", \"path\": \""$2"\" }";}'
#echo
#echo "]"
#du -bs "$@" | awk '{if (NR!=1) {printf ",\n"};printf " { \"directory_size_megabytes\": "$1", \"path\": \""$2"\" }";}'
#du -bs "${1}" | awk '{print "[ { \"bytes\": "$1", \"dudir\": \""$2"\" } ]";}'
echo "["
sudo find "$@" -xdev -type f -size +100M -exec du -sh {} ';' | sort -rh | head -n5 | awk '{if (NR!=1) {printf ",\n"};printf " { \"big_file_size\": "$1", \"path\": \""$2"\" }";}'
echo
echo "]"
[[inputs.exec]]
# ## Commands array
commands = [ "/usr/local/bin/metrics-exec_du.sh /opt/veeam/veeam1","sudo du -hx /opt/veeam/prd_veeam-gwy_01" ]
# "/tmp/test.sh",
# "/usr/bin/mycollector --foo=bar",
# "/tmp/collect_*.sh"
# ## Timeout for each command to complete.
timeout = "30s"
name_override = "du"
# ## measurement name suffix (for separating different commands)
name_suffix = "_du"
# ## Data format to consume.
# ## Each data format has its own unique set of configuration options, read
# ## more about them here:
# ## https://github.com/influxdata/telegraf/blob/master/docs/DATA_FORMATS_INPUT.md
data_format = "json"
tag_keys = [ "filesize" ]
I am getting the following error:
telegraf --debug --config /etc/telegraf/telegraf.conf --input-filter exec --test
2022-05-25T17:41:17Z E! Unable to open /var/log/telegraf/telegraf.log (open /var/log/telegraf/telegraf.log: permission denied), using stderr
2022-05-25T17:41:17Z I! Starting Telegraf 1.22.1
2022-05-25T17:41:17Z I! Loaded inputs: exec
2022-05-25T17:41:17Z I! Loaded aggregators:
2022-05-25T17:41:17Z I! Loaded processors:
2022-05-25T17:41:17Z W! Outputs are not used in testing mode!
2022-05-25T17:41:17Z I! Tags enabled: host=prdxpromapp01.panerabread.com
2022-05-25T17:41:17Z D! [agent] Initializing plugins
2022-05-25T17:41:17Z D! [agent] Starting service inputs
2022-05-25T17:41:21Z E! [inputs.exec] Error in plugin: invalid character 'T' after top-level value
2022-05-25T17:41:36Z E! [inputs.exec] Error in plugin: invalid character 'T' after object key:value pair
2022-05-25T17:41:36Z D! [agent] Stopping service inputs
2022-05-25T17:41:36Z D! [agent] Input channel closed
2022-05-25T17:41:36Z D! [agent] Stopped Successfully
2022-05-25T17:41:36Z E! [telegraf] Error running agent: input plugins recorded 2 errors
