Hello Community
I’m trying to parse some metrics collected from syslog through exec plugin, see below telegraf config .
[[inputs.exec]]
## Commands array
commands = ["bash script.sh"]
data_format = "influx"
timeout = "5s"
cat script.sh
syslog-ng-ctl stats | grep -Ei ".*nginx.*" | awk -F";" '{ print "syslog,destination="$2,"stats="$5,"value="$6}'
current behavior
Telegraf error :
E! [inputs.exec] Error in plugin: metric parse error: expected field at 1:44:
But when i run the script I got the expected behavior !!
syslog,destination=nginx_srv stats=truncated_bytes value=0
syslog,destination=nginx_srv stats=eps_since_start value=1548
syslog,destination=nginx_srv stats=msg_size_max value=1151
Thanks in advance for your help
