Hi guys,
I need your help.
I Have 2 Problems:
1. My Main Problem:
I want to monitor my SQL Server backups. For this purpose I have written a Powershell script. The Powershell script gets the information when the backups were created and how long the backups took.
Telegraf does not seem to get along with the date field “start” and “end”. I get the error message:
2020-11-18T10:42:31Z E! [inputs.exec] Error in plugin: metric parse error: expected field at 1:64: “Backup,backup_type=Log,db_server=HOSTNAME\\INSTANCENAME start=11/18/2020 01:00:54,end=11/18/2020 01:00:54,BackupSize=746496,db_child="DB_NAME"”
The date is structured as follows:
2020-11-18 01:00:00
do you have an idea what I am doing wrong?
Enclosed is the Powershell script that fetches the data from the SQL Server:
$Datenquelle = "HOSTNAME\INSTANCENAME"
$Datenbank = "master"
$connectionString = "Server=$Datenquelle; " + "Integrated Security=SSPI; " + "Database=$Datenbank"
$Verbindung = New-Object System.Data.SqlClient.SqlConnection
$Verbindung.ConnectionString = $connectionString
$Verbindung.Open()
$Query = "
USE MSDB
SELECT
bs.server_name AS db_server, -- Server name
bs.database_name AS db_child, -- Database name
CASE bs.compatibility_level
WHEN 110 THEN 'SQL Server 2012'
WHEN 120 THEN 'SQL Server 2014'
WHEN 130 THEN 'SQL Server 2016'
WHEN 140 THEN 'SQL Server 2017'
WHEN 150 THEN 'SQL Server 2019'
END AS Compability , -- Return backup compatibility level
CASE bs.type
WHEN 'D' THEN 'Full'
WHEN 'I' THEN 'Differential'
WHEN 'L' THEN 'Log'
WHEN 'F' THEN 'File or filegroup'
WHEN 'G' THEN 'Differential file'
WHEN 'P' THEN 'Partial'
WHEN 'Q' THEN 'Differential partial'
END AS backup_type, -- Type of database backup
bs.backup_start_date AS 'start', -- Backup start Datum
bs.backup_finish_date AS 'end', -- Backup abgeschlossen Datum
bs.backup_size AS [BackupSize] -- Normal backup size (In bytes)
FROM msdb.dbo.backupset bs WITH (NOLOCK)
INNER JOIN msdb.dbo.backupmediafamily bmf WITH (NOLOCK)
ON (bs.media_set_id=bmf.media_set_id)
WHERE bs.backup_finish_date >= DATEADD(MI, -1440, GetDate())
ORDER BY bs.backup_start_date DESC
$Befehl = $Verbindung.CreateCommand()
$Befehl.CommandText = $Query
$Resultat = $Befehl.ExecuteReader()
$Backups = new-object System.Data.DataTable
$Backups.Load($Resultat)
$Verbindung.Close()
$Measurement = "Backup"
$TagList = "db_server","backup_type"
$MetricList = "db_child","BackupSize","start","end"
$Backups | ConvertTo-Metric -Measure $Measurement -MetricProperty $MetricList -TagProperty $TagList | ConvertTo-InfluxLineString -ExcludeEmptyMetric -WarningAction SilentlyContinue
2. My Second (Design Problem):
My design problem: Telegraf sets the SQL server name, which is structured as follows:
HOSTNAME\SQL_INSTANCENAME
makes 4x a backslash. Why?
