Hello
Im configuring a input.file with telegraf
im reading for a file.log
the problem is the text have lines since 2012 to 2024. only 1 line per day
i send the data to influx using grok
is there some way to see for example lines from 2024 only? or the last 10 lines for example…
if i use input.file it sends all the lines to influx but only i want the last so i think is better input.tail but is difficult to test if is work with a “telegraf --test --debug” because as i say file is updated each 24h aprox … i would like test with last lines to test if input.line it works ok as input.file does
[[inputs.file]]
files = ["C:\\items\\logs\\events.log"]
data_format = "grok"
grok_patterns = [
'^<%{NUMBER}>%{NUMBER} %{TIMESTAMP_ISO8601:timestamp} %{WORD:server_name:tag} \[threshold@%{NUMBER:threshold_value} name="%{DATA:metric_name:tag}" value="%{NUMBER:metric_value}(?:K)?" threshold="%{DATA:metric_threshold}"\] %{GREEDYDATA:rest_of_line}'
grok_timezone = "UTC"
name_override = 'events_log'
[[processors.defaults]]
[processors.defaults.fields]
metric_threshold = "N/A"
with this conf seems to work good, telegraf --test shows me info
event_log,metric_name=yuth.sr,metric_threshold=“50”,metric_value=“58.0”,rest_of_line=more data info",threshold_value=“11453”,timestamp=“2024-03-06T03:06:14Z” 1709722675000000000
if use this conf
[[inputs.tail]]
from_beginning = false
watch_method = "poll"
grok_patterns = [
telegraf --test show me that
C:\Telegraf>telegraf --test --debug --config telegraf_agent.d\event_log.conf
2024-03-06T11:52:52Z I! Starting Telegraf 1.21.4
2024-03-06T11:52:52Z I! Loaded inputs: tail
2024-03-06T11:52:52Z I! Loaded aggregators:
2024-03-06T11:52:52Z I! Loaded processors: defaults
2024-03-06T11:52:52Z W! e[31mOutputs are not used in testing mode!e[0m
2024-03-06T11:52:52Z I! Tags enabled: host=ri3343
2024-03-06T11:52:52Z D! [agent] Initializing plugins
2024-03-06T11:52:52Z D! [agent] Starting service inputs
2024-03-06T11:52:52Z D! [inputs.tail] Tail added for “C:\items\logs\events.log”
2024-03-06T11:52:52Z D! [agent] Stopping service inputs
2024-03-06T11:52:52Z D! [inputs.tail] Recording offset 15615917 for “C:\items\logs\events.log”
2024-03-06T11:52:52Z D! [inputs.tail] Tail removed for “C:\items\logs\events.log”
2024-03-06T11:52:52Z D! [agent] Input channel closed
2024-03-06T11:52:52Z D! [agent] Processor channel closed
2024-03-06T11:52:52Z D! [agent] Stopped Successfully
