[Input.Modbus] not start after reboot & Error in plugin
I am using telegraf 1.18 and Influxfdb 1.8.5. in Raspberry pi 3 B+.
Config below Input modbus Serial controller
[[inputs.modbus]]
name = “Meter1”
slave_id = 1
timeout = “2s”
busy_retries = 10
busy_retries_wait = “200ms”
### Serial (RS485; RS232)
  controller = "file:///dev/ttyUSB0"
  baud_rate = 9600
  data_bits = 8
  parity = "N"
  stop_bits = 1
  transmission_mode = "RTU"
$ sudo systemctl status telegraf
 telegraf[446]: 2021-05-19T06:20:30Z E! [inputs.modbus] Error in plugin
$ sudo telegraf --test
Started and Showed Measurement value without error
If I Start with $ sudo telegraf
telegraf Stared , loaded Input.Modbus and data collection working perfectly.
After reboot the data collection not started automatically. I also tried serial port permission permanent process. Can’t find the solutions for auto start . when I entered manually $sudo telegraf then it will started collection.
How to enable auto collection for Input.Modbus.
Any one face this issue.
I think you should check the permission for the telegraf user to access the tty interface, which is most probably what is preventing telegraf to run: you overcome this limit when you run with sudo, as you have full rights.
Hi… Thanks…
I already provided permission for system user ttyUSB0 and it also work well $ telegraf (without sudo) The main problem is the system reboot after the Input.Modbus collection not started.
Anyway, How to provide permission for telegraf user.
Try from here usb - How do I allow a non-default user to use serial device ttyUSB0? - Ask Ubuntu
i tried this process both https://www.programmersought.com/article/990156421/… not solved issue.
sudo adduser pi dialout
The user `pi' is already a member of `dialout'
The telegraf user is not “pi” but “telegraf”, if you didn’t change it on purpose.
Run this and check which is the user
cat /lib/systemd/system/telegraf.service | grep "User"
Thank you so much !!!
Added Telegraf user to dialout
$ cat /lib/systemd/system/telegraf.service | grep “User”
User=telegraf
$ sudo adduser telegraf dialout
Adding user telegraf' to group dialout’ …
Adding user telegraf to group dialout
Done.
After reboot the Modbus Collection started automatically.
Have a nice day…
