Hello guys. I hope you can help me because I am very close to get crazy.
I have got a new heating-system in my house. I can start a http requests
and get a json as response… Telegraf cant handle that json and i dont
know why.
The response i get is:
"system":{
"L_ambient":"74",
"L_errors":"0",
"L_usb_stick":"false"
"hk1":{
"L_roomtemp_act":"0",
"L_roomtemp_set":"220",
"L_flowtemp_act":"492",
"L_flowtemp_set":"482",
"L_comfort":"0",
"L_state":"32",
"L_statetext":"Heizbetrieb aktiv",
"L_pump":"true",
"remote_override":"0",
"mode_auto":"1",
"time_prg":"0",
"temp_setback":"180",
"temp_heat":"220",
"temp_vacation":"150",
"name":"Heizkreis",
"oekomode":"0",
"autocomfort":"-1",
"autocomfort_sunset":"0",
"autocomfort_sunrise":"0"
"pu1":{
"L_tpo_act":"542",
"L_tpo_set":"532",
"L_tpm_act":"528",
"L_tpm_set":"532",
"L_pump_release":"542",
"L_pump":"23",
"L_state":"256",
"L_statetext":"Anforderung Ein",
"mintemp_off":"80",
"mintemp_on":"80",
"ext_mintemp_off":"80",
"ext_mintemp_on":"80"
"ww1":{
"L_temp_set":"500",
"L_ontemp_act":"551",
"L_offtemp_act":"551",
"L_pump":"false",
"L_state":"8208",
"L_statetext":"Zeit innerhalb Zeitprogramm|Anforderung Aus",
"time_prg":"0",
"sensor_on":"0",
"sensor_off":"0",
"mode_auto":"1",
"mode_dhw":"1",
"heat_once":"false",
"temp_min_set":"300",
"temp_max_set":"550",
"name":"",
"smartstart":"0",
"use_boiler_heat":"0",
"oekomode":"0"
"error":{
How can I handle this… My config for that:
[[inputs.httpjson]]
interval = "5m"
name = "Oekofenanlage"
#method = "GET"
servers = [
"http://192.168.0.123:1337/xxxx/all"
Can the “linebreaks” being a problem? The response is pure text, without a header.
I also tried things like filtering and so on.
many thanks in advance
Ivo
