Hello!
I want to get some metrics from device with telegraf. Device has API (http://10.1.0.1/status) and i can to get JSON data from it. APi returns JSON with difficult structure (several nested arrays and some of these arrays do not have an explicit key/value pair, they can be accessed by index.)
My JSON:
"instance-id": "DEV-MLFF-ANPR",
"api-version": "2.1",
"devices:cameras:status": {
"framerates": [
"23.8095",
"23.8095",
"25",
"25",
"25"
"names": [
"front_cam_1",
"front_cam_2",
"rear_cam_1",
"rear_cam_2",
"side_cam"
"statuses": [
"live",
"live",
"live",
"live",
"live"
"timestamps": [
"1730371112186",
"1730371112186",
"1730371112186",
"1730371112186",
"1730371112186"
"module-id": "devices:cameras:status",
"timestamp": "1730371131742",
"duration": "60054"
"lpr:app:cpu-load": {
"load": "162.01815002913995",
"module-id": "lpr:app:cpu-load",
"timestamp": "1730371131737",
"duration": "60055"
"lpr:app:memory-usage": {
"vm-rss": "7561860",
"vm-size": "13503580",
"module-id": "lpr:app:memory-usage",
"timestamp": "1730371131724",
"duration": "60058"
"lpr:app:ram-disk:usage": {
"available": "6011834368",
"used": "430616576",
"module-id": "lpr:app:ram-disk:usage",
"timestamp": "1730371131740",
"duration": "60055"
"lpr:app:run": {
"state": "online",
"module-id": "lpr:app:run",
"duration": "60055"
"lpr:transits:statistic": {
"scores": "",
"sides": "",
"statuses": "",
"module-id": "lpr:transits:statistic",
"duration": "255990617"
"system:cpu:load": {
"by-cores": [
"3.3579583613163195",
"0.51675279213202197",
"12.247622225930252",
"7.4061012167166282",
"17.817749872730356",
"0.68247739293635901",
"0.71538068472151251",
"27.511281965569111",
"0.93442349407642245",
"8.7094617184888001",
"17.397933254277486",
"0.39993334444259288",
"12.196861626248216",
"3.5655210439257488",
"19.102435769102435",
"12.559081701553005",
"9.7630173564753004",
"12.318596017549782",
"8.3138953682105967",
"13.744315310763012"
"cores": "20",
"total": "9.4849661675174257",
"module-id": "system:cpu:load",
"timestamp": "1730371131723",
"duration": "60058"
"system:cpu:thermal": {
"cpu-package-0": "33",
"module-id": "system:cpu:thermal",
"duration": "60058"
"system:disk:usage": {
"available": "184195661824",
"used": "58732937216",
"module-id": "system:disk:usage",
"duration": "60055"
"system:disks:smart": {
"names": [
"sdc",
"storage-2",
"main"
"sysnames": [
"sdc",
"sdb",
"sda"
"temperatures": [
"41",
"46",
"46"
"timestamps": [
"1730371095000",
"1730371094000",
"1730371094000"
"module-id": "system:disks:smart",
"duration": "60054"
"system:memory:usage": {
"hardware-corrupted": "0",
"mem-active": "1033092",
"mem-available": "54069480",
"mem-free": "867168",
"mem-inactive": "60021148",
"mem-shared": "586012",
"mem-total": "65569080",
"swap-free": "16711932",
"swap-total": "16777212",
"module-id": "system:memory:usage",
"duration": "60058"
I create config and can get some metrics, my config:
[inputs]
[[inputs.http]]
# this section working and return data
urls = [ "http://10.1.0.1/status" ]
method = "GET"
name_override = "device_info"
json_string_fields = ["instance-id", "api-version"]
data_format = "json"
success_status_codes = [200]
[inputs.http.tags]
devid = "64"
[[inputs.http]]
# this section IS NOT working and return data
method = "GET"
name_override = "device_data_status"
json_string_fields = ["devices:cameras:status.framerates"]
json_query = "devices:cameras:status.framerates.0"
[inputs.http.tags]
devid = "64"
[[inputs.http]]
method = "GET"
name_override = "device_data_mem"
json_string_fields = ["mem-active", "mem-available", "mem-free", "mem-total", "swap-free", "swap-total"]
json_query = "system:memory:usage"
[inputs.http.tags]
devid = "64"
When i tested config file i get next data:
device_data_mem,devid=64,host=smit-dev1,url=http://10.1.0.1/status mem-active="5728700",mem-available="52924888",mem-free="455340",mem-total="65569080",swap-free="16440572",swap-total="16777212" 1730461094000000000
> device_info,devid=64,host=smit-dev1,url=http://10.1.0.1/status api-version="2.1",instance-id="DEV-MLFF-ANPR" 1730461094000000000
and i recieve error: Error running agent: input plugins recorded 1 errors because second block my config file (it is there has string devices:cameras:status.framerates.0) try to collect data and see array and can not process it, because my array has no keys, my array has indexs and values.
I use gjson.dev - to get right string for json_query [1] but it is not working
Help me please, I am at a dead end.
If you can suggest another solution (any option to get all data from JSON) i will thanks you very much
