I have an Instance of influxdb (v1.3.7) powered by Kubernetes on Azure Cloud.
The storage is an Azure-File (one of M$ Cloud Storage formats) mounted through SMB on /var/lib/influxdb.
Kubernetes also foresees so called life- and readiness-probes which periodically shall check the inflxudb. My probes are defined as following:
livenessProbe:
httpGet:
path: /ping
port: 8086
initialDelaySeconds: 90
timeoutSeconds: 5
periodSeconds: 15
readinessProbe:
httpGet:
path: /ping
port: api
initialDelaySeconds: 60
periodSeconds: 15
timeoutSeconds: 5
As you can see, the /ping API get’s called quite often. Initially I have set periodSeconds to 1 sec. Influxdb’s Memory (RAM) usage has grown within short time up to several GBs. Influxdb finally crashed. After I purged the content of /var/lib/influxdb it started up again.
Now, as I have set the interval to 15 seconds the situation relaxed. But still the storage usage under _inter grows constantly.
After running this for one day I see that I also will run into troubles sooner & later with that interval. Is there a way to ignore calls to the /ping-API instead of disabling the whole [monitor]-module?
