I am deploying influxdb2 OSS to an AKS (Azure Kubernetes Service) cluster, using the helm chart from helm-charts/charts/influxdb2 at master · influxdata/helm-charts · GitHub.
The deployment succeeds when using the default settings.
However, I need to use a specific Azure Storage Account, so I need to change as follows:
—values.yaml
Persist data to a persistent volume
persistence:
enabled: true
If true will use an existing PVC instead of creating one
useExisting: true
Name of existing PVC to be used in the influx deployment
influxdb data Persistent Volume Storage Class
If defined, storageClassName:
If set to “-”, storageClassName: “”, which disables dynamic provisioning
If undefined (the default) or set to null, no storageClassName spec is
set, choosing the default provisioner. (gp2 on AWS, standard on
GKE, AWS & OpenStack)
storageClass: “-”
storageClass: “hf-azurefile”
accessMode: ReadWriteOnce
mountPath: /var/lib/influxdb2
—persistent-volume-claim.yaml
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
name: “{{- if not (empty .Values.persistence.name) }}{{ .Values.persistence.name }}{{- else }}{{ template “influxdb.fullname” . }}{{- end }}”
labels:
{{- include “influxdb.labels” . | nindent 4 }}
annotations:
# helm.sh/resource-policy: “keep”
spec:
accessModes:
- {{ .Values.persistence.accessMode | quote }}
resources:
requests:
storage: {{ .Values.persistence.size | quote }}
{{- if .Values.persistence.storageClass }}
{{- if (eq “-” .Values.persistence.storageClass) }}
{{- else }}
storageClassName: “{{ .Values.persistence.storageClass }}”
{{- end }}
{{- end }}
volumeName: influxdb2-pv
where influxdb2-pv is a pre-created volume bound to an Azure Storage Account File share
With this modified configuration, the influxdb container crashes at start. Logs:
- Readiness probe failed: Get “http://10.244.0.19:8086/health”: dial tcp 10.244.0.19:8086: connect: connection refused
- Liveness probe failed: Get “http://10.244.0.19:8086/health”: dial tcp 10.244.0.19:8086: connect: connection refused
** 2021-11-26T00:43:44. info pinging influxd… {“system”: “docker”, “ping_attempt”: “7”}
** ts=2021-11-26T00:43:44.126091Z lvl=error msg=“Failed to apply SQL migrations” log_id=0Y2Q~wH0000 error=“database is locked”
** Error: database is locked
** 2021-11-26T00:43:45. info pinging influxd… {“system”: “docker”, “ping_attempt”: “8”}
** /entrypoint.sh: line 162: kill: (88) - No such process
** 2021-11-26T00:43:45. error influxd crashed during startup {“system”: “docker”, “total_pings”: “9”}
