When optimizing/analysing your queries, both during development as on production system you need to be able to see how long queries take.
When using flux there is the “Flux query log” which enables that.
When using InfluxQL instead of Flux, I could not find such things.
I’m not sure if this is the right forum for problem-reports/feature requests. If not please guide me where I should file such requests.
steps to reproduce
- Issue a query using fluxql
- inspect logging with journalctl
Result
queries are logged, but query duration is not included in the log line.
Mar 02 11:50:11 linode1 influxd-systemd-start.sh[444806]: ts=2023-03-02T11:50:11.255092Z lvl=info msg="executing new query" log_id=0gKYFNvG000 query="SELECT * FROM p1_values WHERE time > '2023-03-02T11:45:00Z';"
Mar 02 11:50:11 linode1 influxd-systemd-start.sh[444806]: ts=2023-03-02T11:50:11.256723Z lvl=info msg="Executing query" log_id=0gKYFNvG000 service=query query="SELECT * FROM energy.\"example-rp\".p1_values WHERE time > '2023-03-02T11:45:00Z'"
Expected
I’d expected for every logged query, to also log the duration of the execution (and size of result)
version info
influxdb2 2.6.1-1
on ubuntu 20.04
