I use influxdb1.8 to create a continuous query for a measurement, but
after the creation is successful, the database does not automatically
generate the specified data storage table? Has anyone encountered
this situation? Can you give me some guidance?
For example, my continuous query statement is:
CREATE CONTINUOUS QUERY "cq_test" ON "test_database"
BEGIN
SELECT sum("number") INTO "sum_number" FROM
"test_measurement" GROUP BY time(1d)
END
After executing it, the measurement “sum_number” is not automatically generated in the database of “test_database”.
