InfluxDB value with factor
Good morning,
I have this simple query, I want to understand how to divide the data here with a factor.
Ex: value / 10 = …
from(bucket: "VH_Messwerte")
  |> filter(fn: (r) => r["_measurement"] == "mqtt_consumer")
  |> filter(fn: (r) => r["topic"] == "Energie/VH/Spannung/L1" or r["topic"] == "Energie/VH/Spannung/L2" or r["topic"] == "Energie/VH/Spannung/L3")
  |> yield(name: "mean")
Thanks for your help
Matthias
Hello @matze1708,
You can use the map function.
  |> map(fn: (r) => ({ _value: r._value /10 }))
Thank you, very much.
is it also possible to Calculate one value /100 and another value / 10, in the same query?
Thank you
Hello @matze1708,
Yes you can do:
  |> map(fn: (r) => ({ _value_by_100: r._value /100, _value_by_10:  r._value/10 }))
