This is difficult to grasp as its not clear what end-points/routes should be used for health in Influx DB 2.x
I’m using a monitoring software that is capable of pushing metrics to InfluxDB 2.x and I need to use Telegraf to suport a specific use-case.
When I connect directly to Influxdb (v2.5.1) everything works as expected but when I use the Telegraf ( 1.28.5) Influxdb 2.x input listener I can see my application uses the /ping endpoint and that Telegraf returns a 404
However I can use the route /api/v2/ready but nothing else.
When I’m reading the test-cases I find this: https://github.com/influxdata/telegraf/blob/release-1.28/plugins/inputs/influxdb_v2_listener/influxdb_v2_listener_test.go
Where it expects the read route.
But reading the API Docs /ping should be available in 2.x?
https://docs.influxdata.com/influxdb/v2/api/#operation/GetPing
Whats’ the correct method and should I file a bug report for the Telegraf Plugin? Or should I use another plugin?
Thanks for reading.
