Influxdb V2.3 unexpected fault address
hi
I am running InfluxDB on a single instance 8 core VM with 1T RAM. The VM is running Linux version 3.10.0-1160.62.1.el7.x86_64 and InfluxDB v2.3.0+SNAPSHOT.090f681737.
I have get twice error ablout “unexpected fault address”. The log as follow:
It automatically recovers after 12 minutes, but I lose my some data.
I don’t know how to solve the problem. Please help to check the reason.
Happy to provide more information if needed.
Hello @liuyang0716,
What version of InfluxDB are you running?
Thank you
I don’t know if this is useful at all?
Thanks for your reply.
I used InfluxDB v2.3.0+SNAPSHOT.090f681737 in my single instance and I do not use docker container.
It runs by “systemctl start influxdb.service” directly
Hi Anaisdg,
I have upgraded to InfluxDB 2.6.1. but I still got the error about “unexpected fault address”.
The log as follow:
