InfluxDB Restarting Automatically Randomly
Hi All,
I am observing strange issue for my InfluxDB 1.8.10.
Issue: InfluxDB Restarting Automatically Randomly.
Error in Logfile:
Mar 28 06:52:02 influx influxd-systemd-start.sh[14374]: unexpected fault address 0x7b35af7b5000
Mar 28 06:52:02 influx influxd-systemd-start.sh[14374]: fatal error: fault
Mar 28 06:52:02 influx influxd-systemd-start.sh[14374]: [signal SIGSEGV: segmentation violation code=0x1 addr=0x7b35af7b5000 pc=0x12a1fd0]
Mar 28 06:52:02 influx influxd-systemd-start.sh[14374]: goroutine 11953909117 [running]:
Mar 28 06:52:02 influx influxd-systemd-start.sh[14374]: runtime.throw(0x169e54a, 0x5)
Mar 28 06:52:02 influx influxd-systemd-start.sh[14374]: #011/usr/local/go/src/runtime/panic.go:774 +0x72 fp=0xc2e2d8cc18 sp=0xc2e2d8cbe8 pc=0x431272
Mar 28 06:52:02 influx influxd-systemd-start.sh[14374]: runtime.sigpanic()
Mar 28 06:52:09 influx influxd-systemd-start.sh[14374]: #011/usr/local/go/src/net/http/server.go:2928 +0x384
Mar 28 06:52:10 influx systemd[1]: influxdbsud.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Mar 28 06:52:10 influx systemd[1]: influxdbsud.service: Failed with result ‘exit-code’.
Mar 28 06:52:10 influx systemd[1]: influxdbsud.service: Consumed 1month 6d 13h 29min 42.403s CPU time.
Mar 28 06:52:10 influx systemd[1]: influxdbsud.service: Scheduled restart job, restart counter is at 1.
Mar 28 06:52:10 influx systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
Mar 28 06:52:10 influx systemd[1]: Starting InfluxDB is an open-source, distributed, time series database…
Mar 28 06:52:10 influx influxd-systemd-start.sh[116443]:
Mar 28 06:52:10 influx influxd-systemd-start.sh[116440]: InfluxDB started
Mar 28 06:52:10 influx systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
Mar 28 06:52:10 influx influxd-systemd-start.sh[116441]: ts=2024-03-28T06:52:10.842072Z lvl=info msg=“InfluxDB starting” log_id=0oCy7trW000 version=1.8.10 branch=1.8 commit=688e697c51fd
System Environment:
Operating System: Ubuntu 22.04 on Azure
InfluxDB Version: 1.8.10
CPU: 32vCPU
RAM: 128GB
Database Size: 80GB
Disk Type: SSD
cache-max-memory: 32GB
Index Type: TSM
Any help/suggestions are appreciated in advance.
With Regards
Hello @Satish2007,
I’m really not sure.
This issue has some commands to dig into logs a little better to try and understand what’s happening:
And maybe this would be useful?
like:
 influx_inspect verify /path/to/influx/data
You might also want to try the slack channel, but also we’re on v3 now so there’s limited support for v1. :frowning:
Hi @Anaisdg ,
Thanks it was helpful. Not getting the error as of now.
