I want to import this csv-file example.csv into an influxdb with the name PDMCC
example.csv
User;2D;german;41
User;2D;spanish;115
User;2D;mexican;0
User;2D;brasilian;77
User;2D;all;381
the conf for telegraf is pretty simple
bash-4.2$ cat test9.conf
Configuration for telegraf agent
[agent]
Default data collection interval for all inputs
interval = “3s”
If set to true, do no set the “host” tag in the telegraf agent.
omit_hostname = true
OUTPUT PLUGINS
Configuration for sending metrics to InfluxDB
[[outputs.influxdb]]
urls = [“http://127.0.0.1:8086”]
database = “PDMCC”
INPUT PLUGINS
Reload and gather from file[s] on telegraf’s interval.
[[inputs.file]]
files = [“example.csv”]
data_format = “csv”
csv_column_names = [“1_category”,“2_type”,“3_item”,“value”]
csv_delimiter = “;”
bash-4.2$
the test-run is OK, every line is taken
bash-4.2$ telegraf -config test9.conf -test
file 1_category=“User”,2_type=“2D”,3_item=“german”,value=41i 1603529684000000000
file 1_category=“User”,2_type=“2D”,3_item=“spanish”,value=115i 1603529684000000000
file 1_category=“User”,2_type=“2D”,3_item=“mexican”,value=0i 1603529684000000000
file 1_category=“User”,2_type=“2D”,3_item=“brasilian”,value=77i 1603529684000000000
file 1_category=“User”,2_type=“2D”,3_item=“all”,value=381i 1603529684000000000
bash-4.2$
but in the influxdb, in the measurement file
only the last line of example.csv arrives
select * from file
time 1_category 2_type 3_item value
1603529754000000000 User 2D all 381
1603529757000000000 User 2D all 381
1603529760000000000 User 2D all 381
1603529763000000000 User 2D all 381
Can you tell, what is wrong or missing in the config-file?
