We are spawning the influxd by executing the binary directly. Is there any way to trigger shutdown in such usage?
we are not explicitly using any process manager.
In that case, I will simply kill the influxd process. As SIGTERM is default signal for kill, it should do the trick.
@rawkode Please correct me if this will create any issues.
That should be fine, just don’t send a SIGKILL
@rawkode Thanks for quick response.
For safe-side, I will explicitly mention SIGTERM like
kill -15 <pid>
